my key broke off in the deadbolt and I had to take it apart to get the key out but the pens in the springs fell out the lock how do I put them back in which order Do they go in
Not easy. You need to insert the pins so that the valleys on the key cause the different lengths of pins to align with a critical point in the turning mechanism. It is often impossible to see the alignment and you are stuck with trial and error. For most locks, a new cylinder is relatively cheap, although it means distributing new keys to all users. – bib Jul 27 '13 at 17:54
This little picture shows how you have to get the pins installed so that the key will allow the lock cylinder to rotate properly.
