I had some cracked/spalling bricks on my home as a result of water getting in and freezing during the winter. I went ahead and replaced five bricks (three on top and two below) and accidentally used leftover cement that I had in an unmarked container, rather than my leftover mortar. Will this end up compromising the structure of the home? Given that it's only five bricks, would it need to be replaced?
see my answer here: diy.stackexchange.com/questions/25639/… – HerrBag Jul 8 '13 at 21:05
The reason not to use cement is that it's typically harder than the bricks. It's probably OK as-is, but if there is a problem down the road, you'll likely see it as damaged bricks...at which point you can replace both the bricks and the cement. – DA01 Jul 9 '13 at 3:04
up vote 1 down vote accepted
It depends...
These days, bricks are used far less frequently as the "structure" of residential homes, due to the higher chance of failure from lateral movement (such as an earthquake). Depending on the construction of your home, they may provide little to no structural value and may be purely cosmetic. If they are cosmetic, the structure should not be compromised any more than it was when the mortar failed (which would typically mean "insignificant"). If they are structural, your concerns may be warranted.
If your house was built more recently, uses primarily wood framing including along the interior sides of your exterior walls, and your rafters/trusses are fastened to said framing (rather than fastened to the bricks), it is more likely to be cosmetic. It is extremely telling in the case where the brick stops before it reaches your roofing timbers. That is not to say the brick provides absolutely no structural value -- it still serves a purpose and can help resist movement, but cosmetic brick does not bear the structural loads. If you've seen a home built with brick recently, you likely saw a free-standing structure, covered with plywood and a waterproofing/resistant/wicking/other material, before the brick "walls" were added.
One of the biggest differences between cement and mortar is typically the lack of aggregate (sand) in cement. If your mixture contained sand, you probably used the mortar as intended. The sand exists, essentially, to give the cement something to stick to, just like rocks do for concrete. Without the sand, I suspect that the cement will eventually loosen, crack, and fall away much sooner than mortar; it also will not prevent movement of the bricks in the same way mortar does, because the "connection" that the provides is missing.
If you cannot determine that your brick is solely cosmetic, I would recommend that you remove the cement and replace the bricks using mortar. When in doubt, consult a professional about your specific situation.
Bricks have a range of hardnesses, the mortars need to match. Soft 'reclaimed bricks' might need a type N mortar(750psi) or even a hydraulic lime mortar. – HerrBag Jul 8 '13 at 21:01
Hopefully I didn't imply that cosmetic brick will be perfectly fine with plain cement -- I meant quite the opposite in that it is going to fail again, and much sooner than with the proper mortar. – Jacob S Jul 8 '13 at 21:22
I wouldn't bother re-doing it. When it does fail (if it does) then use proper mortar. – Matt Jul 8 '13 at 22:55
@JacobS I was confirming your answer and adding a small addition. – HerrBag Jul 11 '13 at 1:33
