Take the 2-minute tour ×
I have removed the fence, but the original drilled hole still contains the (I call it) an anchor sleeve, the fence post when assembled using these pre-drilled holes with aluminum sleeves tapped down to be flush with the pool deck surface do not come out. Any tool or method that would help me?
What material is the sleeve in? Do you know how the bottom of the sleeve is shaped? Is there material (such as concrete) in the bottom of the sleeve? Pictures would help. –  bib Jul 8 '13 at 13:26
add comment
