Our basement has had difficulty with water in the past, from intrusions through the side (fixed by gutters) and chimneys (fixed by chimney caps). Most recently, however, water has been collecting on and dripping from cold water pipes and the basement refrigerator on to the concrete floor below. The amount of water isn't massive, but it's significant enough to cause a problem in and around the affected areas.
The problem, obviously, is humidity. We have placed a 30 pint Frigidaire dehumidifier in the basement, but the problem is that on humid days 30 pints doesn't go very far. We have to empty it some days twice, other days three or four times in a 24 hour period.
Update: Sorry, part of my description got cut off. The dehumidifier can be hooked up to a drain unit, but I'm not sure where or how to drain the water safely. We don't have a basement drain, the sump area lacks a pump and also is where the radon remediation system works, and so the only thing I can think of is to put the dehumidifier on a shelf and gravity drain it with a garden hose out a window, which obviously isn't ideal from an aesthetic standpoint.
So, suggestions welcome.
Is there a floor drain in your basement? Do you have an A/C? If so, where does it drain? – Steven Jul 8 '13 at 0:44
We do not have a floor drain. Our A/C is a standalone LG unit which has exactly the same problem: we have to drain it manually. – sogrady Jul 8 '13 at 0:49
that's a possibility, but while it reduces the number of times we'd have to dump the container, we'd still have to check it. two other problems: the automated overflow shutoff that the unit has wouldn't work this way, and the weight of a garbage can full of water is an issue. – sogrady Jul 8 '13 at 1:34
Do you have a washing machine drain in the basement? If you can get the dehumidifier high enough, it can gravity drain there. You can hang a shelf from the joists if they're exposed, or lag a sturdy shelf into the wall. – Tim B Jul 8 '13 at 2:00
@TimB: we don't have a washer there now, but we do plan on relocating our current washer there. and while we probably need the dehumidifier in the room next to the laundry room for coverage reasons, i can always use the pump mentioned below to get the water from the one room to the laundry room and then the washing machine drain. – sogrady Jul 8 '13 at 2:27
up vote 11 down vote accepted
The simplist solution to dehumidifying in an area with no drain is to use a dehimidifier with a built in pump such as this one:
dehumid pump
It has a long thin tube that can be routed to an area with a drain (such as a washing machine drainpipe) or to the outside (through a window frame or a very small hole drilled through the wall). If to the outside, you need to direct it away from the foundation.
There are a few versions available and they tend to cost a good bit more than a simple tank type, but the convenience may make it worthwhile.
If you already have a good dehumidifier and don't want the expense of replacing it, you may be able to use an add-on dehumidifier pump such as this one
dehumid pump
It is hooked up to the demidifier and then uses a thin tube to move the water in the same manner as a pumping dehumidifier.
That pump looks perfect. I'll still have to figure out where to drain it to - maybe a simple PVC pipe punched through and directed towards drainage, but 15' of vertical would be more than enough. – sogrady Jul 8 '13 at 2:08
One quick addition: the condensate pumps mentioned can be purchased cheaper on Amazon. – sogrady Jul 8 '13 at 2:24
I'm just looking here wondering if the unit has the pump does the drain line have to be shortened or just leave the excess coiled. Routed the line through a hole i put in the wall. I chose the pump style since I have no sump or any other place to drain it with a garden hose and its 16 steps to the crawl space. Go for the pump dehumidifier
If this is a question, it should probably be asked separately where it could get whatever attention might be needed. – Ben Jun 5 '15 at 3:19
The OP already has a dehumidifier, I doubt they want to buy another one with a pump. – Doresoom Jun 5 '15 at 13:26
Indeed, not looking to run out and buy a second dehumidifier. – sogrady Jun 6 '15 at 0:52
