When we bought our house in 2008, we opted for the cheapest oak trim. Around doors, windows, baseboards, cabinets, behind the clothes dryer, fireplace surround and mantel, absolutely everywhere.
We're slowly tiring of the stained oak look, and are interested in something a little higher-end, like maple or cherry. I do realize that replacing a couple thousand linear feet of trim is possible with a lot of work. Painting is doable, but we prefer being able to see wood grain.
Are there any other options to cover oak trim and cabinets with a different type of wood?
Depends on how much overcoat of varnish/poly... a glaze coat can give a different (darker) look, while letting the grain be seen through – HerrBag Jul 3 '13 at 19:39
I assume this is the thin/narrow trim you see in houses today? An an alternative to (or addition to) upgrading the wood, consider using a much wider trim style. Even painted MDF can look a lot better than the super narrow stuff in a lot of homes. I came from a 1930's house with 12" moulding and 6" door trim to an 80's house with 4" floor, 3" doors. I've been slowly replacing it all with more substantially sized pieces. – DA01 Jul 4 '13 at 4:35
For the mill work outside of the cabinetry, you have two practical options:
  1. Paint the trim. But note that oak has large pores, so you will see grain texture through the paint unless is was previously filled (which is unlikely). This is probably your least expensive option.
  2. Replace the trim. This won't be cheap. Trim is among the most expensive finishing steps, especially when you get into premium quality hardwoods.
This one isn't practical to do for an entire house, but it could be done
  • Strip, fill, apply lighter dye or stain. Again, oak has a very pronounced grain which can't be fully hidden easily. You can use a wood filler to level the surface but the texture will still have an 'oak' feel to it. This option is a ton of work even for a small project, but you can create a reasonable illusion of a different wood species in color, if not in texture.
As for the cabinetry:
You could paint them, but I don't recommend it except as a temporary measure. Instead, apply adhesive-backed wood veneer to the cabinet boxes and have new doors made up in your preferred wood species. You'll have to be careful cutting and installing the veneer or it will look decidedly sloppy. Best to have an experienced professional do it. Here is a site that sells self-adhesive wood veneers. Here is a company that manufactures replacement cabinet doors. A quick web search will turn up many other companies that provide this service.
