I was removing some ancient hanging cabinets in my small laundry room when I found an old vent of some kind. It had been completely hidden behind the old cabinetry. My dryer vents out through the roof so I want to close and seal this opening, especially before it gets really cold.
I believe the gist of it is that I fill the hole with insulation and put some drywall on the inside. I then cover the outside with some sort of aluminum plate or plywood. Any experts out there have input as to choice of insulation or external covering? I think the box is too big for the kind of spray foam one would use around pipe holes. I have stucco on the outside of my wood house. Also, should I remove the inner walls of the box or just leave well enough alone?
alt text
up vote 6 down vote accepted
I would probably use some rigid foam insulation (2 or 3" is probably good, it's generally rated at R7 per inch - and you can stack it, it doesn't have to be a solid piece), and then use spray foam to seal it up around the edges and hold it in place.
It looks like a metal sill all the way around, so that's going to cause a lot of heat transfer anyways - ideally, to make it as warm as possible, get rid of the metal. You can also then pull off the trim and just put some backing in, and a piece of drywall (or plaster) to finish up the inside.
The most important part is making sure it's sealed to the elements from the outside, like rain/snow. You don't want water coming in and getting into your walls. Depending on the outside condition, get rid of the louvres. Ideally you would put a piece of plywood in place and then if you have siding on the rest of your house, put siding over that as well. You might also be able to just leave the lovres there, but seal them up (with caulking outside, spray foam inside) so they don't open and don't let anything in.
I like your idea about the spray foam insulation holding the rigid insulation in place. It is metal plating on the inside of the box. What do you think about putting plywood over the metal? Would that help against heat transfer? I'm just worried about creating a huge mess by ripping out the current plates. I pulled off the trim last night. I'll have to figure out how to get rid of the louvres. The bottom 3 or so are open to the outside while the ones at the top are obscured by the back of the rain gutters. How would one protect the plywood from moisture? Some sort of rubber material? – Ryan Nov 18 '10 at 20:54
I'd just put the rigid foam right against the inside of the louvres, then seal it up. I guess since the metal is coming right to the edge of the wall, I'm just thinking it would be difficult to put drywall back afterwards. That will also cause the heat transfer, though maybe it's not a huge deal if it's just relatively thin sheet metal. Metal is a good heat conductor. It doesn't matter what is around it, the fact the metal goes from outside to inside is means it will act like a pathway for heat to move from outside in or vice-versa. – gregmac Nov 19 '10 at 2:31
I am very concerned about moisture and vermin in this case. You need to seal the outside properly, much more than the inside cosmetics...it actually is a fairly easy fix. Just don't want your place to look like a trailer repair! There are always a lot of considerations that are hard to get from a short description. You really need to seal the outside hole and get rid of the vent hardware first, waterproof it, insulate it, then fix the interior.
Any sort of insulation would do - it might be whatever you can scrounge. It doesn't seem worth buying a whole roll/sheet for such a small space.
I might be tempted to fix a plate on the inside to stop any water getting in. This could be any suitable material and it might be easier to fix from the inside.
As for the interior - I'd leave the frame blank it off with a piece of plywood fitted on the inside. You might end up doing more damage to the wall ripping it out.
Thanks Chris, I actually did damage the wall somewhat ripping off the frame but it wasn't too bad. They had used really big nails when they attached it originally. I like using FixAll/FixItAll for deeper pits in plaster/drywall and I think it worked well for repairing what I did yesterday. – Ryan Nov 18 '10 at 20:52
You want to check and make sure the vent wasn't intentionally left there (I'm thinking like if it was maybe a crawl space air vent so it doesn't get moisture buildup somewhere else if air circulation/flow is blocked)? I have no idea but am also a learn the hard way usually as I go and hate odd, seems so simple to fix....but why Was it left ...especially when installing cabinet or whatever, they already had tools to do it why half ass it...just saying but I'm probably overthinking it since I have no actual training or expertise. Call around and schedule a energy home audit (call elec or gas co. Usually free) and ask their opinion just for reassurance. Good luck and knowledge isn't always power huh...wasn't it nice being ignorant having no idea hole was there in the first place, lol.
