I have all the information on how to install the PEX plumbing system, but nothing on how to flush it or how to pressure test the PEX system.
Can someone help?
Your caps lock key appears to be broken, please look into getting a new keyboard so that we don't assume you're yelling at us. – BMitch Jul 2 '13 at 18:39
PEX is just like any other plumbing pipe/system, except that it is flexible and <joke>rumored to taste like cheese to rodents</joke>. Flush and pressure test like you would any other plumbing system. – Jacob S Jul 2 '13 at 18:51
Well a copper system has different variables, you are saying in essence that is is flushed just like i would a copper system? I find it hard to believe, chlorine"? – JOE CURRAN Jul 2 '13 at 19:32
The generally accepted definition of "flushing" is the running of water through the system to remove sediment/flux/debris, as in a "flush and fill". Are you asking how to "sanitize" a PEX plumbing system? Sanitization is typically only done when on well water. Most public water supplies use chlorine to disinfect the water, and copper pipes do not require sanitization (but are flushed to remove flux/sediment) -- at least, that I am aware of in residential situations. You may need to update your question. – Jacob S Jul 2 '13 at 19:57
@JacobS - I heard it was Hazel Nuts. But then the guy was a bit squirrelly. – Fiasco Labs Jul 2 '13 at 20:29
