I'm installing some Lack floating shelves from IKEA. I have two holes into the drywall with anchors (the metal kind with large threads), and one hole into the stud.
The problem is, I got confused and screwed a wall anchor into the wooden stud. I was pre-drilling holes for the anchors, so there's also a hole (larger than the screw) in the stud. The anchors say they are fine to use with wood, but what do you guys think? Do I need to back these out and start over, or will these hold my shelves like this? I am expecting the shelves to hold 20–30 lbs.
up vote 3 down vote accepted
Typically you would remove them, however the anchor you are using is marketed as a "stud solver" meaning that it can be driven into a stud. I think it is fine to leave them.
If you were using small plastic drywall anchors then I'd definitely remove them and drive a screw directly into the stud.
I use 'em and like 'em – HerrBag Jun 24 '13 at 0:05
@Steven. How do I remove the wall anchor? I can't just cut off the head and push the rest through cause there's a stud there and I can't pull it out cause it sits there very "sturdily" (for a lack of a better word). So how do you remove wall anchor if there's a stud behind the anchor? – Jenia Ivanov Jun 20 at 17:36
If they are the type you install with a screwdriver, then just back them out (unscrew them). Otherwise a pair of needle nose plyers and some muscle should get them out. Worst case bang them in a bit more with a hammer and put some drywall compound on top then re-paint. – Steven Jun 20 at 17:43
