I have this device on my outdoor water faucet. It is leaking water in all directions and by leaking, I mean pouring water everywhere.
What is the purpose of this device and how can I remove it so I can replace it if it is needed ? I don't have an in-house winter valve, so I'm guessing that it has some usage for winter.
I tried to remove it using a vise-grip but to no good.
Two metallic joins that seem connected together
Water pouring out everywhere
up vote 3 down vote accepted
Backflow preventer: The fitting closest to the faucet MUST unscrew CCW.
Looking at your bib at the house siding, its not secured. Use a second wrench on the faucet, torquing in the opposite direction to the wrench on the backflow adapter. This will prevent you from busting the water pipe and REALLY making a mess. Backflow article
Feel around the side of the fitting that is closest to the house that you can't see. Some are held in place by a small allen head set screw – mikes Jun 20 '13 at 20:22
We called a plumber. Effectively, I don't want to cause a breakage in the piping in the basement ceiling. I need to repair this because we are getting a new pool and I don't want to fill the pool with that much water being wasted. – Pierre-Alain Vigeant Jun 20 '13 at 21:57
Leaking Add-on vacuum breakers or backflow preventers often are non-removeable per municipality mandate, they're installed with snap-off head setscrews that permanently mates the threads to the hose bib.
Since they're meant to be a permanent fixture, if they were removable, due to corrosion, they now aren't unless you're willing to apply some heat to the vacuum breaker and a chunk of ice to the faucet to get a little differential expansion going to break them loose. You have to do this without cooking the packing around the valve stem, or you have yet another problem leak.
Given the age and crustyness, you'll be replacing the faucet soon anyway, so go for the permanent solution which is to install a frost proof faucet with built-in vacuum breaker and choose a quality manufacturer like Arrowhead or Silcock who has replacement parts available.
I'm no expert here, but I really think you should call your city for that, cause I'm pretty sure that it's their problem and they will come and fix it for you.
The city isn't responsible for anything after their shutoff valve, which is often co-located with the water meter near the street. – BMitch Jun 21 '13 at 14:56
I'm telling him that cause for me, the same problem, the city came to my house and changed everything free of charge. – user13586 Jun 21 '13 at 15:00
It is true that I could call them. Too bad I read your answer on a friday afternoon when all town office are closed and that we have an holiday on Monday. But I got a plumber to inspect the device. Won't cost that much and I will have a completely new water faucet and not just the backflow fixture. – Pierre-Alain Vigeant Jun 21 '13 at 17:57
