Take the 2-minute tour ×
I am hanging more drywall and will be doing a basement ceiling. I generally start in a corner and work my way out. I use glue on the joists and then drywall screws.
Is the glue needed? I learned to use glue on ceiling from an old drywall pro. He said his callbacks went to almost zero for sagging ceilings once he started gluing. Second question is that I try to line my pieces to meet midjoist so I can get a screw for each piece on the joist. Problem is that common drywall screwed often break the drywall when done that close to the edge and then if I angle the screw, that is another issue. So how do you screw in your middle ceiling joins?
A friend of mine today said he nails his joins because the screws tend to damage the boards when too close to edge. He did not know the type of nails - just said drywall nails. Is this good practice? and what kind of nails? –  DMoore Jun 20 '13 at 16:38
6 Answers 6
up vote 8 down vote accepted
I find that it's best to attach 1x3 furring strips across the joists. It's worth the extra cost. The 1x3 will give you 1.25 inches of screwing space, so you don't have to be quite as accurate with your cuts. Glue is not needed, but will reduce screw pops by making the assembly more 'solid'. I always use adhesive when I can (when there is no vapor barrier or insulation covering the wood).
Also, if you can place the tapered edges on the joist lines, they will be less prone to break than a cut edge. Also, some installers have butt joints ending between studs held together by a backer board such as Rock Splicer, which is wide enough to avoid breaking board edge. –  bib Jun 20 '13 at 12:39
The furring strips are a good idea. Seems like a bit of work and money but if it works I would be willing to do it. –  DMoore Jun 20 '13 at 14:50
THe strips can be 'tuned" with shims and a laser to adjust for uneven joists, giving you a much flatter ceiling. Once the shims are coplanar, the drywall can be screwed down without adhesive. Adhesive allows for bridging. (you don't want to screw down a low spot, you either bend the board or punch the screw through, netting no holding power). –  HerrBag Jun 20 '13 at 18:47
How do you deal with pot lights when you have the furring strips? –  DMoore Jul 29 '13 at 16:45
You just attach them to the strips instead of the joists. –  Edwin Jul 30 '13 at 1:08
Some helpful pointers:
  • If you can, get sheets that cover the width or length of the room. Less seams.
  • Run sheets perpindicular to framing.
  • For the edges, you can always add a 2x4 if your cut is not accurate along the joist to give extra space to screw, All edges need to be securely fastened. Furing strips can also solve this issue. One needs to be far enough away from the edge so the drywall does not break up near the edge or it will lose holding strength and/or sag.
  • Use drywall screws - 1 screw per 12 inches on the joist, if you have an edge, every 6 inches. That should be 48 screws per 4x8. Nails are ok, but I prefer screws. Drywall screw guns make attachment a snap.
  • Glue is extra, but I don't see any harm in using it as it will add more grip, so go for it!
  • Get a drywall joist or some friends to hold the board over thier head. Your back will thank you later.
Long sheets are a good idea if you don't have a lot of lights. I cant imagine making 5-6 cutouts while putting up a 16' sheet. And a 16' sheet couldn't even get down my stairs. –  DMoore Jun 21 '13 at 5:08
No need for glue. NEVER use nails!! Always screws. I use 1 1/4" drywall screws. I start from one corner and run my boards across the ceiling framing. (As if you were applying plywood to the floor). The smooth edge of the board is called the flat. The shorter rough edge is called the butt. Make sure your boards are staggered and the butt joints don't line up with each other. If your ceiling is say 20' wide your boards would run right to left 8' 8' and 4'. Then start your next row from left to right 8', 8', and then 4'. There is also no need for furring strips. Yes your butt joints have to break in the middle of the 2x10 or 12. But don't put the screws right at the edge. You should have plenty of room for the screws without damaging the rock. I've been installing drywall and finishing for almost 30 years and I can honestly say I've never had a call back for poor installation or finishing.
Photos should be added here, rather than a link to an external site (upload to imgur.com and provide a link if you don't have the rep to post them yourself). Including the website in your profile rather than in your answer is also preferable so you don't get flagged as spam. And welcome to the site. –  BMitch Jun 28 '13 at 20:58
I've used coarse drywall screws into wooden joists for years and never had a failure. The fine screws tend to strip out more often. If screws do strip out (keep spinning) I get them out and try somewhere else that is close, an inch or two away. If my joists or studs are extra wavy I'll screw a length of 2"x4" along the wavy section for more holding area. I've never used glue but I like the idea. Still, I wouldn't want to be the guy scraping the drywall off the ceiling at the next remodel. When I'm working on my own home I skim-coat the entire surface and then kiss-sand it so that the texture is all the same. More work but the painted finish is really nice.
If you're not into old-school, another method is to use drywall clips. With this method, you intentionally make the drywall but together between joists, and use the clips to join the butts together. I've also used this method with success. The advantage here is that it finishes slightly better than butting the drywall over wood. Remarkably, it doesn't seem to affect strength. Make sure you use fine threaded screws with the clips.
Drywall clipsenter image description here
I have 30 years in the drywall business. I always use screws, never ringshank, buttercup, or black coated drywall nails. The down side of nails is that when you drive the nail to recess it you bust the gypsum between the paper, causing air to form. That's how you get nail pops. Glue is OK; the only advantage of glue is to use less screws, and I would not recommend that on the ceiling only walls.
