I need ideas for making some plywood attractive. Ideally I want to lighten it and then varnish it, so it ends up with a pine finish. Is this possible? Alternatively I might stain it with a diluted white paint before varnishing. Is this a good idea? I want to avoid a plain color: leave some visible grain if possible.
Edit: a hardware store suggested I try applying some bleach. I will try that on an offcut and report back
Related: diy.stackexchange.com/q/19993/22 – Niall C. Jun 19 '13 at 13:36
up vote 1 down vote accepted
I would use Oxalic acid (in deck "brightners") before using bleach. Bleach not only breaks down color, but accelerates wood deterioration.
Be sure to neutralize as directed; with borax diluted in water or bicarbonate of soda in water.
