I recently got some contractors over to repair a section of my house and they unknowingly spilt a small amount of acid on my marble floor.
They did not attend to it immediately and the acid corroded the surface of the marble floor.
How do I repair it?
You would normally clean marble with etch spots with hydrogen peroxide or bleach and then repolish. From the sound of it yours may be more severely damaged. I would try both on a small spot and see how it goes.
If your marble is actually corroded then you will have to polish until you hit uncorroded marble.
What sort of compound or chemical should I use for polishing? – Japster Jun 19 '13 at 5:55
baking soda and water - flooring stores also sell marble solutions. Also on your "stain" if you see that it is coming out a little with bleach or hydrogen peroxide. You may need to let these sit on there for a long time. You can do that by mixing hydrogen peroxide (or bleach - I would do them seperate) with paper towel bits and letting the paper towel bits sit on stain until it is dry - which may take a day or so. And if something is working keep doing it until the spot is gone. It may take repeat cleanings. – DMoore Jun 19 '13 at 6:03
Corrosion of marble (a form of metamorphic limestone) is not a stain, but rather a dissolving of the base rock.
The solution (if not too deep) might involve surface grinding, honing and polishing in place, but is not a DIY project. Discuss with a marble installer/fabricator.
Another solution (if the marble tile is available) is to replace the one tile.
I was assuming they were using the word corroded, when it really was a stain. They might as well treat it as a stain because if it is corroded its not really a DIY unless you can still find the same tiles. – DMoore Jun 19 '13 at 20:50
