A member of my household thought our garbage disposal was a magic ray gun that obliterated anything poured down its black hole. The plumber cleared a glue-like substance from the pipes underneath the sink with a screwdriver but his auger barely penetrated 5 inches into the main wall pipe that leads to the sewer. I cannot afford to have my pipes cut out and new ones installed so I was just going to use the sink in the basement to clean dishes.
So which is the better option so sewage fumes do not overrun my house:
  1. Easy option: Cap off the sink hole & garbage disposal.
  2. Remove all the pipes under sink & garbage disposal and cap off main pipe at wall.
  3. Leave the P-Trap and cap the pipe off after that.
Any of those options will work, let me reorder them to:
  2. Leave the P-Trap and cap the pipe off after that.
  3. Remove all the pipes under sink & garbage disposal and cap off main pipe at wall.
Now they're in order of ease and how temporary you want. If you want to simply stop the sewage fumes, the P-Trap (filled with water) will do just that so #1 & #2 will do that. #2 & #3 are good but might be a bit overkill especially if you leave the sink in place, even with the sink faucet off you'll have the occasional pot drained/strained in the sink and glass dumped in there. So if you have any drainage left, I'd just leave it and probably just turn off the faucets. If not, personally I'd removed the P-Trap back and cap it, then put a 5-gallon bucket under there.
