Take the 2-minute tour ×
I purchased a refrigerator 8 months ago, but it will not be used right away. It came directly from the showroom. Must I use it now, or I can wait longer before using it?
I'm not sure what you're asking. Can you use a refrigerator which cannot be used? Can you wait more than 8 months for what? –  BMitch Jun 17 '13 at 11:11
Clean empty refrigerators should be stored upright and kept dry. You should prevent moisture building up inside the stored refrigerator - perhaps by removing the door or by keeping the door open.
The manufacturer's instruction booklet may have a section on storage.
Unused refrigerators are a potentially fatal hazard for children, who may get trapped inside. For this reason doors should be removed, locked closed or prevented from being closed (using a child-proof mechanism).
These are good practices, but regarding his concern of whether it can be stored and still be good, I add the following: Refrigeration systems are "sealed" system, use oil-less compressors in most cases, and there are no specific "lifespans" for the refrigerant. This means that, provided you follow the storage practices mentioned by @RedGrittyBrick and store in a location that will not promote rusting, it should be fine to store until you are ready to use it. I recommend a good cleaning before turning it on, with compressed air, just to avoid working additional dust working into the move parts. –  Jacob S Jun 17 '13 at 13:51
If your refrigerator was stored upright, then plug it in and see if it works. Plugging it in isn't going to harm it. And if there is something wrong with it you will need to turn it on to diagnose.
If your refrigerator was stored any other way find the manufacturer's guidelines on how long it needs to be upright. This may range between 15 mins to 1 day. If you can't figure out the manufacturer or make and model then leave it upright for a day before using. It would generally be good practice to cleaning it before turning it on too.
