Tell me more ×
There's a shed near the side of the house with a roof that's pitched to shoot water at the house's foundation. That side of the house also has no gutters. There's a very slight grade to send water towards the front of the house. House is brick veneer, on-slab.
How can I build a drainage system to carry water away from the foundation?
up vote 9 down vote accepted
Here is a pretty quick explanation.
  1. Starting from where the water will enter the drain and ending where the water will flow out, dig a ditch that's about 10 inches deep and 6 inches wide. Keep in mind that you will need to dig deeper if your starting point slopes upward.
  2. Lay about 2 inches of rock into the trench before placing the pipe lengthwise into the ditch.
  3. Cover the pipe with another layer of rocks, again about 2 inches.
  4. Fill in the remaining space with soil and then plant some grass.
Here is a pretty good video, which also shows it's a good idea to add a clean-out.
They also say you should not use flexible corrugated perforated plastic drain pipe, because it cannot be cleaned like rigid pvc can be.
Here's another article about a French / Trench drain:
Basically the same idea, except he doesn't recommend lining the ditch with fabric or putting a sock on the pipe. He does recommend using rigid perforated pipe instead of the corrugated pipe with slits in it.
I like the idea of omitting the fabric (expensive!). Great link. – Steve Jackson Nov 19 '10 at 5:25
@Steve - I dug a French drain on the uphill side of our house 30 years ago. I don't think we even had fabric back then. It worked great - for the first 10 years. I've had to use a sump pump ever since. That crushed rock isn't good for much once it's all silted up. – Ed Staub Sep 24 '11 at 13:38
