I've got an in-ground pool, and a DE filter from Jandy. The pressure gauge is in an assembly bolted to the top. The assembly looks like something like this (image from catalog, mine is pretty much identical):
Jandy gauge
Today, when I powered the system down, the pressure reading didn't change. I pulled the gauge assembly off and tried blowing it out, removing the relief valve, etc, etc, to no avail. I have to assume something has gotten stuck in the gauge inlet.
Is there any good way to fix this? At the moment I can't even figure out how to get the thing apart.
The ring on the front (where clean/dirty are written) does rotate, and if I have no other answer, I'm going to try prying that off and see where it leads me.
UPDATED: @mikes had the right answer - swap the thing out. I ended up swapping out the whole unit, as I had no idea how to (non-destructively) get it apart. Someone else might like to know how to disassemble the thing in order to get at the actual pressure gauge itself:
  • Remove the trim ring. I found a notch on the bottom and pried with a screwdriver Ring removed
  • Unscrew the pressure gauge. It's normally threaded, however whatever they used as a sealant didn't want to let go for me. Excessive force may be required. Because I wasn't sure of what I was looking at, and thought perhaps it was formed in place somehow, I ended up cutting the thing in half to find out. Cut apart
Thus, we can see that as long as you can manage to get enough force on it to unscrew the pressure gauge, it should be possible to replace JUST the gauge portion, instead of the entire unit as I have done.
up vote 2 down vote accepted
My experience with pressure gauges is that yours is broken and unrepairable. The odds of an obstruction causing your issue is a long shot at best. You may be able to replace it with off the shelf parts. If you can connect a "T" fitting to the mounting hole install a gauge on one side and maybe an automotive radiator petcock to the other side. This will give a pressure reading and a air bleed port.
I also have a similar valve (Jandy) it is not broken but the unit when it was new was clear , now it is hazzy, and I can't figure how to clean it so I can read the pressure gage again, any suggestions ?
Welcome to the site. Please use the Ask Question button at the top of the page if you have a question that is not addressed by the information on this page. DIY Stack Exchange is a Q&A site, not a forum, so we expect answers to address the original question. You can link back to this post as a reference for additional context if needed. – Niall C. Mar 14 '14 at 4:04
