I accidentally snapped off one of the hook latches on my microwave door - the door will shut, since the other latch is still there, but the safety mechanism of the oven prevents it from operating (since the second latch is not engaged).
Does anyone have suggestions on how to fix this without taking apart the microwave door (which I find intimidating)?
Nope, I just bought a new one. Too hard getting (correct) replacement part and then installing it. If part broke off inside main unit, really hard.. – HerrBag May 30 '13 at 22:07
Sadly, this is a problem that is almost impossible to solve economically. We had a microwave with a broken handle. While I'm capable (and willing to do so) of making a new handle from scratch, in order to attach it, I would have had to take the door apart. It seems that they make that fairly difficult to do, since it could be a problem if someone damages the seals on the door. In the end, we bought a new microwave. Very sad. – user558 May 31 '13 at 1:10
If you don't want to disassemble the door or replace it, then don't fix it. The dual-hook latch system is designed to ensure that the door is completely closed. Both hooks have matching sensors and both must be actuated for the oven to run. If you don't fix the door, then the only other option is defeating the sensors, which defeats a critical safety feature.
Do not try to defeat the sensors! Microwave radiation is risky. It is made safe by careful design of the doors and seals. If you cannot repair the latch by properly disassembling the door and replacing with standard latches, either bring it in for service or replace it. – bib Jun 30 '13 at 15:23
