I am trying to mount a key hanger on a wall, I drilled two holes in the dry wall, they went right through with little or no resistance, I'm guessing because there was no stud behind the wall. I stuck two plastic anchors into the holes, am I safe to hang that key hanger from the holes without ripping up the wall?
Can this be generalized for any light weight hanging needs? Maybe < 2lbs? It would be more useful in the future to other users that way I would think. – dpollitt May 28 '13 at 20:02
I think you're right. Sorry for the incomplete question. – esp Jun 3 '13 at 5:48
up vote 2 down vote accepted
Monkey hooks are great.
Monkey hooks
Modify the hook using wire snippers. It leaves a tiny hole in the wall and they hold up to 50 pounds. Very very solid for heavy things. I trust these much more than screw+anchor - if I can get these to work for the application. They wont work for everything (like blind housing that has to screw in) but for anything to "hang" they work.
These things are fantastic! I bought like 10 of these. They work fantastic! The package says they hold 35lbs a piece. – esp Jun 3 '13 at 5:49
Good to hear they work. They work even better with some pliers - if you bend the ends in you get the bottom "v" of the hook to jam in the hole. – DMoore Jun 3 '13 at 18:00
Key racks tend to be fairly light, so you shouldn't have any problems using only drywall anchors.
