I changed my old Honeywell thermostat for a new Honeywell WiFi thermostat. I installed it just as the directions stated. I used the alternate C-wire method as the old unit did not have one. Everything worked except for getting power to the air conditioner unit outside. I installed the old one back and it works just fine.
Any ideas as to why it doesn't get power with the new thermostat?
Did you run through the configuration of the thermostat? I know the new one I installed requires you to specify whether it is a heat only or heat/ac system, as well as gas/electric, High perf or not. – Steven May 27 '13 at 20:32
Could you post a link to the installation instructions you followed, and/or summarize the "alternate C-wire method"? This will help folks understand exactly what you did. – Tester101 May 28 '13 at 12:19
Yes I did. I have a gas furnace with central air. I even went through all the settings to make sure I didn't have it wrong. The alternate c-wire method can be found at m.youtube.com/#/… – user13203 May 28 '13 at 15:03
