Take the 2-minute tour ×
A few years ago we got a new heat pipe between the two apartment blocks. The block from where I have taken the picture supplies the other block with hot water.
I am very surprised that the pipe can heat up the ground in such a large area and even melt the snow.
Question
Is this normal/expected that heat pipes does this?
Normally, these things are run through an insulated conduit. There's only so much that insulation can do. It only slows down heat migration. You have a system that runs 24/7. That's a lot of time and a lot of heat over time. Unless you have a long term cold spell, this is pretty normal. –  Fiasco Labs May 26 '13 at 16:33
add comment
