I have a Rinnai Infinity XR20. It's about 3 years old. I've just recently noticed a peculiar issue with it that I hadn't noticed before. If I turn on a cold tap like the one to the garden hose and then turn it off, the unit momentarily fires.
I've verified this occurs now on all cold taps in the house even those that aren't connected to the hot via a mixer.
My guess is it's the shock wave caused by water hammer which is causing the unit to think that water has started flowing when it hasn't.
I asked my local plumber and he agrees but isn't able to offer a solution. He says he hasn't seen this problem before and will ask around for me. In the mean time I rang up Rinnai and the technician suggested I could fit a non-return valve on the outflow of the Infinity. However, that doesn't make sense to me.
What suggestions do you have to fix it? Should I fit a water hammer arrestor to the inflow of the infinity?
a water hammer arrestor may fix the problem but the unit firing over such a small wave seems strange. Ill look up the flow switch assembly in a minute and get back to you – UNECS May 23 '13 at 8:06
Just a guess, it probably has internal pressure balance valving, similar to the anti-scald on shower valves. The anti hammer cartridge (for both supplies) would be a reasonable response. Adding a pair at the washer hoses is a DIY friendly exercise, available as an inline 'T' that has dual hose threads.. no soldering. (though I LIKE soldering) – HerrBag May 23 '13 at 12:49
I had the same problem with the heater firing up when the toilet was refilling from the cold waterline. I put a non-return valve on the pipe just below the heater on the cold water inlet. It has fixed the problem: no odd firing of the heater any more.
Thanks I may just try that. – Matt Dec 29 '13 at 20:10
protected by Community Dec 31 '13 at 14:24
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
Would you like to answer one of these unanswered questions instead?
