I was redoing the silicone dilation around the bath-tub, using the silicone mastic from a tube. Unfortunately, I stained the tub and a tile with silicone. You cannot see it really, but they got quite slippery, which is obviously frowned upon.
I failed to clean them with abrasive cleaner, and trying to "clod it" by hands didn't help either (this works with acrylic mastic and I supposed the silicone one would be the same, is it not, though). How can I clean it off so that the surface becomes less slippery, as it was before?
up vote 1 down vote accepted
This works on dried silicone and is pretty non-toxic
Sometimes, I've had success with an eraser:
It won't damage tile, but results depend on how porous/grippy the tile surface is.
Amazon sells them, so should any local Office Supply or School Supply store.
The tile is quite "rough" hence not slippery itself an probably quite porous. Can you please provide a link to a reasonable e-shop that sells this item? Thanks – yo' May 15 '13 at 14:50
