I am replacing a few interior doors and I need to know if the existing door is Right Handed or Left Handed so I have them drilled correctly. Sounds like the acronyms for this are RH and LH. This also would apply for new pre-hung doors as well I assume as they are all marked that way at the mega home improvement stores.
Not only besides RH or LH, you need to determine swing direction. Trust me, this needs to be agreed upon. When I built the additional room onto my house, I thought 84 Lumber understood the direction of door swing and they didn't. There is left inswing, right inswing, left outswing, and right outswing. The door handle on my exterior door is on the right-hand side, but it is considered a left-hand outswing. Whereas my front door swings in, and the handle is on the right hand side so it is considered a right-hand inswing. Make sure you know what you are buying before you spend the money!
As a homeowner, I have installed many doors, and every time I do I have to re-learn how to "determine door swing". Just make sure you write it down before you order the door, it is easy to get confused again when you go to your local home improvement store. This website should help: http://www.naturalhandyman.com/iip/infdoor/infdoorhand.html
..if you are still confused, just Google: "determine door swing". |
whether a door is an exterior or iinterior door the designation is the same. Think of RH as right hinge. if the door is swinging away from you the hinge is on the right side. for a left hinge door, if the door is swinging away from you the hinges are on the left side. Inswing or outswing only matters with exterior doors where they have a sill. The handing or hinging is still determined the same way. |
It's best explained on this page: http://www.specialtydoorhardware.com/door-handedness/ Left Hand – Hinges on the left, opens inward. Left Hand Reverse – Hinges on the left, opens outward. Right Hand – Hinges on the right, opens inward. Right Hand Reverse – Hinges on the right, opens outward. |
With the door closed, stand on the hinged side of the door. If you can see the hinges with the door closed you are on the hinged side of the door. If your left hand is closest to the door knob it is a left hand door. If your right hand is closest to the door knob it is a right hand door. This method works in the store where the doors are strapped shut. On exterior doors make sure some one didn't set the door down upside down; this will change things a bit. |
Converting Comment to Answer: Stand in such a way that the door will swing open towards you. Inswing and outswing have to do with the way the jamb is constructed and the orientation of the lock bolt. If you're installing interior doors in an existing frame, and doing the lockset yourself, then there's no need to worry about in and out swings. If you're ordering pre-hung interior doors, again it doesn't matter, but make sure you're standing on the right side of the opening when you make your decision. I modified 0A0D's image with some "L --- ^ --- R" labels . The V or ^ indicates which way you are facing.
When you pull the door towards you, which side is the door knob on? LEFT or RIGHT. If you can't pull the door, you're on the wrong side. Anyone who gives you a longer answer than that is either confused or pulling your leg. |
protected by Niall C. Dec 23 '12 at 16:24
This question is protected to prevent "thanks!", "me too!", or spam answers by new users. To answer it, you must have earned at least 10 reputation on this site.
