Does anyone know what would happen? Does the ballast limit the power? If the T5 HO lamps were less expensive than T5 non-HO lamps, would it be ok to just use them in a non-HO luminaire?
The HO bulbs require more power output to operate than regular bulbs... and that is why there is an HO ballast, to provide that extra power. You could put a regular bulb in an HO fixture, but not vice versa.
HO always needs more power... Standards pull only what they need. As will all power supply type devices, the source can feed less load, but not more. – Fiasco Labs Aug 9 '13 at 21:07
@FiascoLabs This information is simply not correct and is dangerous advice. Do not do this! Florescent devices are negative resistance devices and do NOT work the way you think. See: diy.stackexchange.com/questions/58111/… – Ariel Jan 20 '15 at 20:31
