My exterior door deadbolt has gotten stuck - it'll open with the lever but not the key. By spraying WD-40 inside the lock, I've been able to get it to work but it's very stiff. I'd like to remove the lock and inspect the inside, either to clean/lube it or replace it. But I can't figure out how to remove the lock; there's no obvious way to do this. (I'm used to seeing two screws on the inside of the deadbolt, usually under the lever arms when it's horizontal.)
enter image description hereenter image description here
How do I remove this? I can loosen the cover plate on the inside but it doesn't do anything other than rotate a few degrees.
FIY: WD-40 should not be used to lubricate locks – Tester101 May 9 '13 at 12:24
up vote 9 down vote accepted
First thing you need to do is find the set screw that releases the inside handle. then you pry off the escutcheon plate (trim plate). the two screws you are looking for are under the trim plate.
Some Kwikset models use a small plastic pin to retain the knob.It is removed with a pair of needle nose pliers. – mikes May 8 '13 at 23:01
Yep. sometimes a small metal push pin on the knob. – shirlock homes May 8 '13 at 23:22
Removing the set screw requires a tiny 1/16th allen wrench – user21213 Apr 25 '14 at 16:27
It's actually a 1/20 or .05 Allen wrench. Good post though. It let me get my lock replaced – user29923 Dec 19 '14 at 23:59
protected by Community Dec 20 '14 at 0:40
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
