Take the 2-minute tour ×
I've read on some forums (not here) that on top of the caulking areas exposed to water (in this case, my kitchen sink), a sealant should be applied.
Is this standard procedure? If so, are there different types that I need to consider? Any particular suggestions (to a specific product) would be helpful too.
share
up vote 6 down vote accepted
I have never heard of this recommendation. If you are caulking an area that will regularly be exposed to water (sink, shower, etc.) I use a silicone caulk. Silicone caulk is 100% waterproof so there is no need to add any extra sort of sealer.
share
Caulking should be sealing. If it isn't you are using the wrong kind of caulk or your area was prepped wrong.
The question is like asking if you need to put an extra coat on if it is cold outside.
share
This site is currently not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
