I just moved into a place and underneath my bed there's a weird spill. I'm Not sure what it is: it's dark red and thick and dry. Is there any way to clean it or if not cover it up so it doesn't spread germs to the rest of the room? I typically use the space beneath my bed for storing things. If I had to guess it's probably food or vomit or blood.
Here's a picture after treating it a couple times with white vinegar. It's much better! The lighting is poor because it's under my bed so I used an LED head lamp to shine light on it. stain
Hi! Any photos available? – yo' May 15 '13 at 14:12
@tohecz good point, I'll post them asap! – Celeritas May 15 '13 at 16:54
If your carpet is a light color then try white vinegar on it first. I use this for pet stains and its light years beyond any product specifically formulated for stains and 1/20th the cost. It kills germs/bacteria/mold. I pour the vinegar straight from the bottle onto the stain, thoroughly soaking the carpet. It will begin to react with the stain and start fizzing. Once the fizzing stops you can soak it up with a paper towel but its best if you use a steam cleaner with just water in the tank to remove as much of the vinegar and the residual odor as possible. It will have a strong odor that will completely dissipate after two days assuming you sucked enough of it up after application.
Does it matter what the percent of acetic acid in the vinegar is? At the store that had a vinegar for cleaning which was 10% acetic acid (vs the normal vinegar which was 5%) but it cost way more. – Celeritas May 1 '13 at 19:51
I always use 5% stuff that comes in a gallon. Not sure what 10% will do to the carpet's color but you can always test it in a corner of a closet to see. – TugboatCaptain May 1 '13 at 22:30
