I've been looking on how to control power outlets through wifi and I've only found Belkin's WeMo. Are there any alternatives?
closed as off topic by The Evil Greebo, Niall C., Chris Cudmore, BMitch May 1 '13 at 0:26
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here.If this question can be reworded to fit the rules in the help center, please edit the question.
"Shop for me", and/or "google for me" type questions are not considered on topic. – Tester101 Apr 30 '13 at 11:05
@Tester101 I've been googling and I only found WeMo, that's why I was asking for alternatives. – HenryHey Apr 30 '13 at 12:51
It might help if you include what you don't like about Belkin's offering. – Tester101 Apr 30 '13 at 13:01
This question might be useful What is the most common home automation technology. There may be other useful questions in the home-automation tag. – Tester101 Apr 30 '13 at 13:10
Home automation is on the rise now a'days with the advent of smartphones and with wifi becoming more popular in houses.
On the low end, you have equipment like the x10 Commander - this will allow you to control x10 devices from an iPhone / Android phone over WiFi. The commander acts as a bridge between WiFi controllers and x10 devices.
x10 devices can control lights, outlets, thermostats, etc...
On the high end, you have equipment like Crestron; these systems are more expensive, going well into the $1000s and usually used in higher end restaurants and hotels but their not unheard of being used in homes and are more common in higher end homes. These systems can do everything x10 devices can, but are much more advanced with table top displays, ability to schedule events and lighting patterns, etc... Usually a central command unit is required and should be installed by a professional.
