I have a 27" iMac and a second 30" display, and since I'm fairly tall I need them raised off the desk by about 20cm / 8".
What is a good building material/design to build such a stand? I'm looking for a clean/simple look - probably timber painted black.
I'm fairly capable (my dad is a carpenter and I've worked as his off-sider from time to time) but not very experienced and want to keep the budget low.
It needs to be around 1200mm by 350mm and strong enough to hold 30kg/65lb securely.
My 24" monitors sit on top of old phone books! lol – Matt Jul 18 '13 at 2:04
You could build a simple box out of medium-density fiberboard (MDF).
Simple Box
Simple Box (Exploded)
If you really want to get fancy, you could build drawers into the front.
Box with Drawers
You could buy a piece of melamine shelf, a 4x4, and some L-brackets. And build a shelf like this.
Monitor Stand
Monitor Stand Exploded
Trestle styles are strong and scalable to a tall version.
Pine for the understructure, perhaps a laminate for the top.
up vote 0 down vote accepted
In the end I bought a sheet of Melamine and some big chunky pieces of timber that were available on special. I painted the timber black, put some self-adhesive rubber feet on and and attached to the melamine with L brackets.
Note the original plan was to have them raised by ~20cm. I didn't end up doing that.
I'm quite happy with the result.
the result
