I bought a surge-protecting power bar yesterday. It's a seven-outlet model, made by American Power Conversion Corp.; I found it at the thrift store for $4 second-hand. It appeared to be in decent condition, though I did drop it a few feet onto the hard floor shortly after buying it.
Last night, the house was quiet. I plugged the power bar into the wall outlet and turned it on. The "Protection Working" LED lit up. Good.
I then plugged my laptop's AC adapter into the power bar. As I did so, I heard a "pop". The sound was a bit louder than a finger snap, but quieter than a hand clap. My heart started racing.
Wondering if I damaged anything, I turned the laptop on. Thank God, it still works perfectly.
  1. What could have caused the "pop" sound?
  2. Is it safe for me to try plugging other things into the power bar, such as a lamp, to see what happens?
  3. Should I continue to use the power bar, or should I discard it?
Edit: I experimented by plugging the AC adapter into a wall outlet, and unplugging it, a number of times. It indeed sometimes does make a spark and a "pop" sound. I plugged a couple of things into the surge suppressor. It's still working as expected. I'm keeping the surge suppressor. Thanks to Pigrew's answer, I now think the "pop" sound was normal. Pigrew, thank you very much for your answer; I've upvoted and accepted it.
up vote 6 down vote accepted
Popping sounds are generally either a sound from a spark, or a failure of an electronic component. They do not always mean that something failed. For example, plugging in electronics that use lots of power will often cause a small spark to form when plugging them in. As an example, my Lenovo laptop power adapter will often make a sparking noise when I plug it into an outlet and it is not a cause for concern.
Does your power adapter create such a noise when using other outlets? If so, then you may not need to worry at all. See this question for some more details on this transient arcing.
But, sometimes noises do indicate failures, for example when a capacitor, MOV or IC explodes. You could also hear a click when a circuit breaker trips, but this would cause a circuit in your house to be no longer be energized. Some power bars also have internal circuit breakers, which can also make a click when they trip.
In your case, I'd first say that a used surge suppressor probably may not provide much protection for your electronics. If you are concerned about surges, you should look into verifying that your house has a good ground, installing a whole-house surge suppressor, using quality surge suppressors where your electronics are installed on both the power lines and data lines such as telephone or CATV. Surge suppressors do age, and can only handle a certain amount of surge during their lifetime. Ensure that new surge suppressors meet the new UL standard 1449 v3 by checking for a holographic sticker that says "Surge Protection Device".
Now to your other questions:
2) This should be safe. Any over currents should be protected by your house's circuit breakers, and a lamp is a pretty "robust" device that wouldn't be seriously damaged by a bad power supply (though the bulb may burn out). That said, do this in an area where if the power strip catches fire, it won't damage anything, and you could quickly pull the plug out of the wall socket if something bad happens. Don't put water on an electrical fire.
3) As I said above, the power bar may not provide significant surge protection, especially now that it may have failed. You may want to dismantle it (while it is unplugged) and see if there are any burnt/charred/damaged components.
This answer is more of a matter of opinion. To be safest, you could replace it with a high quality surge suppressor, but with some investigation, it is likely as safe to use as any other power bar.
