Tell me more ×
Newbie question.
Why is it that there's a bazillion different types of screws? Why can't we just always use one standard screw type? Are there advantages/disadvantages to the different types? Are there times when one type is preferred over another?
Help me understand why there isn't one screw to rule them all.
This makes me wonder if there isn't a rule to screw them all... – JYelton Apr 5 '11 at 16:04
up vote 23 down vote accepted
Shamelessly ripped off from here, looks like the primary reason why we still have "bad" screws (flat head and Phillips) is that the "better" types of screws are simply more difficult/expensive to manufacture:
The reason for the different styles is cost and torque.
The slotted head screws are cheap and easy to make. But they're completely useless for powered screwdrivers and you can't put much torque on the screw without it either slipping out or stripping the head (and maring the surface of whatever you're screwing). [Mad]
Phillips screws are self-centering, making powered screwdrivers possible. They're somewhat more expensive to produce than slotted-head. They tend to 'cam-out' easily under torque, making it hard to apply much torque. I've heard they were designed that way to prevent overtightning. However, it's not good for exposed fasteners to look stripped.
Robertson-head and allen-head fasteners can handle more torque than phillips-head fasteners, but are more expensive. Because the bottom of the hole is flat (unlike the pointed end of the phillips), there's more contact area and so it's less likely to cam-out. The robertson-head is cheaper than the allen-head, but the allen-head has six points of contact rather than 4, making it less prone to rounding out the hole.
The Torx-head fasteners solve the problem of rounding/stripping by having the flat bottom of the robertson/allen that reduces cam-out, but it has much better contact with the driving bit to prevent stripping the head. The points of the 'star' on the driving bit engage the recesses on the screw at nearly right angles, so it has a very positive contact. Torx is becoming more and more popular because of that, particularly in assembly-line work.
Because they're less likely than a phillips to be damaged when tightening, the allen (internal hex) heads are often used for exposed ('decorative') fasteners on 'some assembly required' furniture. It's also very cheap to make the allen keys, so they usually include one with the fasteners.
Also, allen-head screws on flat-pack buyer-assembled furniture are conducive to having the little plastic covers that snap in. – Dennis Williamson Nov 10 '10 at 0:47
Historical note: Ford went with Phillips screws because Robertson would not sell him the patent. This resulted in Phillips being the standard for American manufacturing, whereas Robertson is more standard in Canada (at least before NAFTA) – Chris Cudmore Nov 10 '10 at 15:04
For what it's worth, we used Robertson-head (square bit) wood screws when working with decking, and I was in love. I didn't cam out of them once, they can take a huge load of torque. Also, don't forget some newer power drills have a torque setting on them that disengages the drive before you mess up your nice-looking phillips head. – Jared Harley Nov 11 '10 at 8:22
First, I really like Eric's answer for practical reasons. But there is another side to screw head diversity: Security.
In the end, it's usually a temporary measure. Once a company invents a new screw, some third party will start selling tools to remove them. But for a time, any new screw design means the only people who can open your parts are "certified" workshops you've given tools to. Personally I see this a lot in electronic equipment, where the original manufacturer wants some aspect of design kept private or doesn't want after-market mods made to things they sell. Nintendo is particularly active in inventing new screws.
Examples of security screws include 3-prong Torx variants, and Allen heads with a raised dot in the middle of the screw head to stop standard Allen wrenches from fitting.
If you'd like to see a much more industrial version, find a car which has been booted and look at the bolt. I've seen circular bolt heads with an off-center circular hollow inside. No shoulders or slots to grab, you have to have a very specific wrench. And, of course, there are security lug nuts for car tires.
If all else fails, use a screw extractor. They work even on hardened/toughened screws and bolts. Security nuts for car wheels only require a hammer and cold chisel, just like you use on rounded over heads. – John Gardeniers Nov 10 '10 at 4:48
Another example - look at the screws next time you're in a public bathroom stall. They're usually driven in by what looks like a normal flathead, but the "reverse" side is smoothed down so they can't be removed by some unruly teenagers looking to cause mayhem (not that they ever do that...) – Jared Harley Nov 11 '10 at 8:24
One of my favorite hobbies is finding ways to defeat said security screws/bolts. Sometimes a slightly modified tool will do the job; other times brute force is necessary. Always a fun pastime. – JYelton Apr 4 '11 at 22:47
I thought it would be useful to include an image/link to some drive types found on screws and bolts (obtained from bontool):
http://www.bontool.com/knowledge_center/Support_files/KC_%20Misc/Screw_Drive_Styles.jpg
Good list. There are some there I've never even heard of, but there are some missing. Some electrical goods like to use a "security" slotted, which is a raised bit in the middle of the slot. And Apple made news a month ago with their "pentalobe" screws. – staticsan Apr 5 '11 at 2:45
Flat-head (slotted) screws are often considered the "junk" of screw heads, but one place they are slightly advantageous is wet applications. You can set the slot vertically, so it will drain out, instead of holding water. This can increase the life of the screw and the wood behind it.
It's a very small point, but it's something.
(I saw a boat builder once who liked to use Robertson screws in visible applications, and set them to look like diamonds.)
I like to turn all of my flathead screws on my outlet covers so that they are all straight across. My wife thinks I'm slightly neurotic (she might be right) – Jared Harley Nov 11 '10 at 8:25
+1 for orienting the screws on outlet and light-switch covers. I always look at that detail when I'm in model homes. LOL! – Dean Hill Dec 13 '11 at 22:25
Same reason there different shapes and sizes of screws. It's because there is no single design of screw or screw head which satisfies all requirements. Even when the Phillips design came out there was almost immediate competition from posi-drive and others (most of which have since disappeared) because the Phillips design leaves a lot to be desired, such as the bit rising in the slots when the screw gets tight. Some designs, such as allen heads, have been around a lot longer and for most purposes are very superior but even then, a countersunk allen head of necessity has a rather small socket which creates other problems, such as a tendency to break the keys. Also, allen heads and other socket designs are mostly only used in hardened materials, which resist the tendency of the socket to deform under pressure.
The reason we currently have so (relatively) few mainstream designs of screws is simple practicality. Nobody, merchant or user, wants to stock the massive number of screws we would need to have to use the best possible design for every possible application, so we compromise and use ones that are adequate in the majority of cases.
All good answers provided so far. There are also self-tampering; i.e. security screws (one-way, star-bit, etc) that you'll see in public bathroom or on subway/train cars, buses, etc. These were prevented to keep people from disassembling structures, maliciously.
There is even a specific drive (and material) that wooden boat makers like to use called Frearson flat head wood screws (silicon bronze). They look like Phillip drive but have a deeper recess which prevents cam-out. But the builder still gets style points for using bronze, Phillip-looking screws as opposed to using a square drive.
So to answer your question in a few words: price, style, efficiency and material/durability.
Also makes selling fasteners for a living all that more challenging.. lots to know! 8)
