So my house and garage have been built with Insulating Concrete Forms (Perform wall to be exact) and I want to attach shelves and cabinets in my garage. Pictures and other lighter stuff have been easy to do with some special plugs and standard picture hangers. But I am unclear about how to attach heavy items. There are no studs to attach to.
Anyone have some ideas on this?
So its just an outer shell that is filled with polystyrene/concrete mixture in the centre? I would have thought using longer screws and wall plugs. You might have to use a concrete drill and drill bit instead of the conventional masonry bits(which will burn out the bits when used on concrete) – ppumkin Apr 16 '13 at 15:34
The material is not like concrete, you could just press the drill bit through the material by hand easily. It's kinda like drywall/paster. – mbrannig Apr 16 '13 at 15:46
All the way through the wall? From the inside too outside? – ppumkin Apr 16 '13 at 15:48
Well there is void, it looks like a cinder blockish item. The material is pretty uniform. But I bet with a long grill bit, I could with my cordless drill get all the way through. – mbrannig Apr 16 '13 at 16:30
OK - Never came across anything like that before. Not really sure what to say. – ppumkin Apr 16 '13 at 19:30
