Sign up ×
I've assembled a set of swings, and am trying to tighten the nuts at the top. The trouble is that they are embedded deep inside a circular hole and I can't get to them with a regular spanner.
What kind of tool should I be using? I had a good look in my local hardware store and couldn't see anything useful.
Here's a (dreadful) diagram of what I mean.
By my standards, that's an excellent diagram. See: –  Chris Cudmore Apr 15 '13 at 16:19
up vote 20 down vote accepted
You should get yourself a socket wrench (also known as a ratchet):
Socket set
Note, no affiliation, but I do like Craftsman tools in this situation. I took a 20 year old wrench like this back because the quick release go stuck in the release position and they replaced it, no questions asked. –  BMitch Apr 15 '13 at 14:36
For deep locations, there are deep sockets as well, about 4-5 the length of the ones shown. Craftsman at 1/4 the price of Snap-On, with a lifetime warranty on applicable tools... They will last a lifetime, unlike a lot of the cheap bubblegum wrapper tinfoil and zinc stuff. –  Fiasco Labs Apr 15 '13 at 15:23
I didn't see one of these in the hardware store, but I did see a "Torque Wrench". Is that the same? –  Urbycoz Apr 15 '13 at 16:07
@Urbycoz: every respectable hardware store will sell socket wrench kits. Ask a staff guy for ratchets and sockets and he'll be able to direct you. –  whatsisname Apr 15 '13 at 17:23
@Urbycoz - If you do not have a "respectable hardware store" in your area then try at an automotive parts store. They sell plenty of socket wrenches. –  Michael Karas Apr 15 '13 at 18:39
You want a nut driver. You can either get a fixed set of them,
Nut driver set
or if you have a socket set, you can just get a nut driver with a square head that you clip the sockets onto:
Nut driver for sockets
Or you could get a set of these, a power drill, and the socket, and use that to get it really tight. If you're going to tighten stuff instead of drill holes with a power drill, I recommend you read our blog post on the proper use of the clutch on a power drill.
Power bar set for drills
If you're spinning the nuts with a drill can you safely use the chromed sockets sold with hand tools; or do you need to use the black type rated for use with impact wrenches. –  Dan Neely Apr 15 '13 at 17:20
@DanNeely Unless it's a hammer drill, the chromed sockets should be fine. –  GalacticCowboy Apr 15 '13 at 17:30
