I've been using it but it's very expensive. The grout powder appears to be normal grout... could I just combine it with some sort of epoxy mix?
up vote 3 down vote accepted
echo Michael. I've used Laticrete's SpectraLock.. There's a lot of engineering there to allow water based haze removal (OK, you do need to add white vinegar, very cheap and non-toxic). Spectralock installation
Off-the-shelf epoxy is going to require a solvent based haze removal (usually lacquer thinner, acetone, or alcohol).. much more hazardous (indoors you'll need an organic respirator) and adds to the cost. Checkout West Systems how to use instructions and videos.
Its doable, but...how many experimental batches are needed to verify proper resin/hardner.filler(grout) ingredient mixes so you get a mix that looks and performs like you want.. There goes your savings..
In the business grouting tile? might be worth it. Doing a one off for a kitchen/bath.. buy a product backed by a warranty, videos, other users (like John Bridges' forum).
My answer to your question is "Probably Not".
That said you are of course free to experiment. Tryout you ideas.
I have done it with clear epoxy and micro spheres to create an un-sanded, white colored grout. I used it on a very small, thin glass mosaic tile. Vinegar and water worked but acetone worked better. If you are to use the spectralock part C I would add some white to the epoxy. My objective was to get away from a sanded product.
that's great! do you have pictures? how smooth is it? – skybreaker Mar 6 '14 at 11:29
