Is this ground termite? This is on the outside of a wall in the backyard. This is the only occurrence of this thing.
Should I be worried? Should I call someone to look at it? OR can I fix this myself?
Yes, that is the result of termites. I'd call a professional, but they can be dealt with DIY if you can do some extra research and probably a bit of work. Try to see what's on the other side of that wall, too. – geerlingguy Mar 27 '13 at 6:53
Nasty little buggers! – shirlock homes Mar 27 '13 at 12:17
up vote 7 down vote accepted
Those are definitely termite tubes. Those are the exploratory tubes that termites make when they come out of the soil and are exposed to air and light. They build the tubes out of dirt and their feces to protect them when out of the ground. Definitely termite tunnels. These are common on the side of a house, or inside a crawl space going up foundation walls.
DIY is definitely an option - a MUCH cheaper option. It's really simply in terms of knowing what to do, the hard part is the digging and drilling, but it's worth it when you know how much you will save. Read this article on my site to learn how to do it yourself: http://www.domyownpestcontrol.com/how-to-perform-termite-treatment-a-87.html
