I have a transparent wine glass which I want to be filled with colored water and then place a light bulb immersed in the water so that when I switch on the bulb the wine glass emits the color of the water (If I fill it with blue color water I get blue light), is it possible in a very inexpensive way?
closed as too localized by Niall C., Chris Cudmore, Steven, BMitch Mar 29 '13 at 21:10
This question is unlikely to help any future visitors; it is only relevant to a small geographic area, a specific moment in time, or an extraordinarily narrow situation that is not generally applicable to the worldwide audience of the internet. For help making this question more broadly applicable, visit the help center.If this question can be reworded to fit the rules in the help center, please edit the question.
You understand that it's inherently dangerous to mix water and electricity, right? As in - potentially fatal? – The Evil Greebo Mar 21 '13 at 16:30
You mean that is the goal. But since you're doing it yourself, and you don't know how to proceed, making this a "my first electrical" project is a great way to turn yourself into a corpse. Have you considered colored light-bulbs instead? – The Evil Greebo Mar 21 '13 at 16:36
The heat of the element will cause a temperature differential between the inside and the water cooled outside of the glass of the bulb, almost definitely cracking it. Now you've got 120/240 v going through a short circuit. – Chris Cudmore Mar 21 '13 at 16:37
I recommend not doing this at all. But, if you insist on playing with electricity and water, might I suggest flashlight bulbs/LEDs and batteries as a power source. – Chris Cudmore Mar 21 '13 at 16:38
Sure. You want to keep the voltage low so you don't run an electrocution risk. Also you want all the wiring encased in clear plastic to keep it dry, and eliminate the possibility of electrolysis, which'd cloud up your water and destroy your circuit. Project is entirely doable, just not trivial. If you go ahead, mes with some LED's on dry land first, so you understand them. Electrolysis: en.wikipedia.org/wiki/Electrolysis – Wayfaring Stranger Mar 21 '13 at 16:52
up vote 3 down vote accepted
You could use mineral oil instead of water, since mineral oil is not conductive. Mineral oil is actually used in some transformers and other electrical devices, to provide insulation, cooling, and other functions. There is a popular YouTube video, where a computer is submerged in mineral oil.
I'm not sure if you'd be able to dye the mineral oil, but you could certainly use colored lights to achieve the affect. Popular Science has an article about making Liquid Lamps, that you might find interesting.
