I'm going to be running 1" blue PVC conduit from all my low voltage boxes to a structured wiring panel. My wiring panel will chase to the attic where necessary and I was wondering what the best practice/code compliant method was for reducing my 1" conduit runs down to the chase. Will I need a junction box somewhere in the attic? Can I just leave the 1" conduits open ended somewhere near the chase(s)?
Tell me more
There isn't much code around low voltage wiring. Leaving the conduits open-ended is fine. If you find junction boxes, that would be nice but not required. |
I would use boxes or at least caps to prevent insects from using your conduit as an expressway. At worst, you could have water moving down from a leak; at best, you might have cold air moving down. |
