Tell me more ×
I'm considering replacing my insufficient 30 gallon gas water heater with a tankless water heater equivalent to 50 gallon gas heater.
I know a 50 gallon heater would serve my needs.
Questions
  • How do I determine the tankless heater equivalent?
  • What are units of measurement for tankless heaters?
House is in USA with 2 showers, 2 bathroom sinks, and a kitchen sink.
1 Answer
up vote 3 down vote accepted
With a tankless water heater it's all about how many degrees the heater can raise a certain quantity of water. In your situation, you will need a heater to raise the temperature of about 5 gallons per minute (two showers running at once or one shower and another hot water tap running). If you live in the north, and the water out of the tap is be 40 degrees in the winter, then you will need the heater to raise that 5 gallons 70+ degrees. If you live in Florida, you may only need it to raise 5 gpm 45 degrees. Information about a water heater you are considering purchasing will include a chart that specifies temerature gain at various flow rates. Choose the one that best meets your demands.
I installed a Vessman tankless water heater running on natural gas. At 5gpm here in Maine, it works great, continuous hot water even with two outlets running and extremely efficient (96%). Has cut my costs in less than half compared to electric 40 gal tank. – shirlock homes Mar 17 at 9:11
