Tell me more ×
Can I get a switch that incorporates 2 dimmers and a manual switch to control a kitchen fan?
"Shop for me" type questions are considered off topic. – Tester101 Mar 11 at 12:17
This is less a shopping and more a "do they exist question", case in point, they don't, at the current time. I think some allowance for "possibility of" questions needs to be addressed. – HerrBag Mar 11 at 16:03
closed as off topic by Steven, Niall C., Tester101 Mar 11 at 12:17
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
Assuming you mean a single gang switch, not a electrical wiring question, yes. From the big box stores in the US at least (Like Lowes and Home Depot) they stock a single gang piece with any combination of up to 4 switches.
The picture shows an example of one at Lowes, make sure to ask someone or read the box because they also sell models that have a dimmer/switch that runs a single line/appliance; for instance, the image I supplied is actually for running 2 fans.
(Picture source: Lowe's stock image of Pass & Seymour/Legrand 300-Watt White 3-Speed Slide Combination Ceiling Fan and Light Control)
Partial credit, 3 speed fan slider != dimmer – HerrBag Mar 10 at 21:26
Not in a single package unless you go to controller based system like X-10 or Z-wave.
I've seen dual dimmers or a dimmer + switch.
