Tell me more ×
This question already has an answer here:
The original strike plate for the deadbolt is mounted with 2 screws on top and 2 screws on bottom. I'm replacing the whole deadbolt and the new strike plate only has 1 screw on top and 1 screw on bottom.
So if I were to screw in the new strike plate down the middle of the old holes, it will probably merge together into one big horizontal gap.
I want to fill up the holes, should I use Minwax Wood Filler for this?
I also heard of a method to use a bunch of toothpicks with wood glue to fill the hole. Which method would be stronger?
Is there any wqy you can just reuse the ojd striker plate? – mikes Mar 10 at 10:25
marked as duplicate by Chris Cudmore, Tester101 Apr 26 at 13:28
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
1 Answer
up vote 4 down vote accepted
Wood filler alone may not fill the entire depth of the screw holes. I would use a piece of dowel, toothpicks, or a carved piece of wood covered in wood glue and fitted tightly into the holes. Using the wood and glue method will give you a nice dense fill so the new screw will not split the remaining original casing.
Do you recommend using toothpicks or going to the hardware store to get some dowels? – Jack Mar 10 at 10:02
since deadbolts tend to have fairly large screws, I would use a dowel that fits snugly as my first choice. you can slightly sharpen the end of the dowel so it goes in easier. Put some glue in the hole and on the dowel. Make sure the dowel is longer than the hole. Tap it in gently with a hammer. After it is dry, cut off excess. – shirlock homes Mar 10 at 10:09
+1 for dowels. I've used them before to patch a hole in a furniture and it worked perfectly. – Maxime Morin Mar 10 at 12:09
