I'm planning to install plastic window wrap on my windows for the winter, but the trim around the windows is nice wood and I don't want to leave a mark on it where the double-sided tape will be.
I've seen cases where a very obvious strip is left behind after removing the double-sided tape, and also where the finish on the trim is damaged when the tape is removed.
Are there ways to prevent damage to the trim, or is it something to worry about when removing the plastic in the spring (e.g. special cleanup procedures)?
