This question already has an answer here:
I have an older furnace, on the switch block I have Y,C.W,R and an unlabeled screw that connects to the shut off it looks like. I need to hook up a thermostat that needs the C wire. I have a spare wire, in the bundle which I hooked up to the c terminal downstairs, from these videos that I've seen it tells me to then bridge the Y and G together, I do not have a G on the block, what do I need to do to get the neutral wire set up
marked as duplicate by Tester101 May 10 '13 at 11:55
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
Forgot to add that I have gas heat only – Brian Miller Mar 7 '13 at 17:07
What is the make and model of the furnace? – Tester101 Mar 7 '13 at 17:27
After more testing I discovered even though its a c wire, it's not pulling 24v, so I'll need to add another 24v to the one wire – Brian Miller Mar 7 '13 at 17:32
It's only a C wire, if it's attached to the C terminals at both ends. It sounds like you're not sure what you're doing, you might want to contact a local HVAC technician before you fry your furnace. – Tester101 Mar 7 '13 at 17:37
This answer might be helpful. – Tester101 Mar 7 '13 at 18:26
You have a C wire, so use it - you don't have to bridge as that is only necessary if you don't have a spare wire.
