With a storm bearing down on the mid-Atlantic US and robocalls from the local power utility warning of the possibility of extended power outages, I figured tonight would be a good time to check the status of my 5700W portable generator. After turning the fuel valve to 'on' and engaging the choke, I pulled the pulled the starting cord, and pulled, and pulled. No luck.
The generator is fairly new -- I bought it at the end of June '12. I last started it a few months ago -- around November I think -- and since then it's been sitting in a dry shed with half a tank of treated gas and the gas cap closed tightly. The gas appears to be okay -- it's not cloudy, doesn't look separated. I get a whiff of gasoline after a few pulls, so I think there's some fuel flowing. The spark plug wire seemed firmly seated, but I pulled it and reseated it just to make sure.
What else should I be looking at to get this small engine started?
