Tell me more ×
I have followed a number of videos, but they all seem to have a copper (?) stem. At this point I'm up to some plastic piece that has no notches (namely around the metal piece) to use a wrench on.
Where do I go from here? I'm thinking that I would pull it out, but don't want to risk it without being sure.
It is leaking, so I'm probably looking to replace more than just the knob.
[EDIT] I went to Lowe's and they cannot help me without knowing the brand. What would be a way to determine the brand? I do not see any labels, here are more pictures:
http://imgur.com/a/DpMZk
There may be yet another screw deep inside the hollow shaft of the plastic piece. If there is a screw in there, take it out and the plastic piece should pull straight out. – shirlock homes Mar 4 at 12:31
There's almost certainly a screw down the shaft like Shirlock said. – The Evil Greebo Mar 4 at 12:46
Do you want to replace the valve or just the handle? Does the other knob fit? if so, take it to a plumbing supply store. They will try it on new valve replacement stems (some have boards of stems already made up) and sell you a new handle – HerrBag Mar 4 at 13:36
The valve manufacturer may be on the back of the brass valve body. Do you have an access panel behind the tub? – HerrBag Mar 8 at 7:09
Know someone who can answer? Share a link to this question via email, Google+, Twitter, or Facebook.
