Tell me more ×
My dog chewed pieces of the frame molding around the glass panes on my front door in the house I am renting....can I just replace that plastic/fiberglass molding?
Do you have a photo of the damage? You can upload it to a photo sharing site like Imgur, Picasa, or Flickr and post a link. – Niall C. Mar 3 at 1:27
1 Answer
If you look on the hinge side of the door you may find a makers tag with a model number. If the door is fairly new the manufacturer may be able to supply a new one. You also might try a glass and window shop. The grid is typically screwed to the door. Small plastic plugs cover the screw heads. Some that I have encountered also have an adhesive applied. Sliding a putty knife under the grid will release the trim.
