I'm having some serious trouble with the immersion heater in my apartment. I believe the set up is similar to the one described in this answer, however there is no thermostat to turn the immersion heater off when the water tank gets hot enough.
Consequently, turning the immersion heater on heats the water non-stop, and ultimately leads to an overflow which causes hot water to come out of the cold taps, and for the toilets to fill with hot water also. Finally, water begins to leak from underneath the boiler. Is this a safe setup?
My landlord has blamed me for the leak, saying that I left the immersion heater on for too long (it was on for a little over an hour). He's now saying that I will be held liable for any future leaks.
Can this problem be put down to misuse of the equipment, or does it indicate a flaw in the system?
