Tell me more ×
I'm using PEX pipes for water tubing, but I'm not sure which sleeve type should I use for hot and cold water pipes.
Whats the difference between black, blue and red sleeves? and which should I be using for hot and cold water pipes
I think universally, red is hot, and blue is cold. – Gunner Feb 24 at 20:16
the black got me confused and made me rethink this :) – Ahmad Saleh Feb 24 at 20:17
Basically, the dye used in the plastic. Most of the stuff being sold around here is clear translucent (undyed) and as mentioned, when dyed is available, red-hot and blue-cold. – Fiasco Labs Feb 24 at 22:11
1 Answer
up vote 5 down vote accepted
The color is just for convenience. Making it easy to identify hot and cold pipes under a house for instance. The chemical makeup and temperature ratings are identical besides the actual dye used to color it.
