Tell me more ×
We are going to be redoing our basement which was done in the 60's and very cold. We have been told to apply Tyvek or tar paper to the walls, stud, then vapour barrier and drywall. We plan on using fiberglass batt insulation because of costs (we are retired and limited income). We would love to do the spray foam and not have to worry about all the vapour barrier and such but we are out of budget - Styrofoams seems like a lot of work by the time you have to cut each piece.
We are going to get some prices by contractors but want to do some work ourselves to keep costs down so of course the behind the scene work is what we want to do - i.e. studding (16 inch on centre and insulating and maybe installing the drywall but not taping and finishing). If we use tar paper, do we just overlap it or do we tape it much like you do the seams of Tyvek? Do we go right to the floor with the paper or, like with the insulation, do we keep it a foot off the ground? Any help, suggestions are greatly appreciated.
Is there a path for moisture to escape, either up and through a traditional wood framed wall, or down through a drain system? And do you have problems with moisture in the basement today? – BMitch Feb 21 at 19:08
Answer to first question - I don't think so not sure what you mean by path for the moisture to escape. Floor drains at other end of house so not near where rec room will be. We have lived in the house almost two years and there have been no signs of water. Currently the room is done in 60's style panelling and carpet from that era also and there is no dampness odour at all in the basement – JanCamp Feb 21 at 19:11
Have you had quotes on spray foam? I found it to be only marginally more expensive than other options. Get an estimate, you might find it worth while. – Chris Cudmore Feb 23 at 15:30
"Should I use Tyvek or tar paper on basement walls?"
Neither. No building paper or wrap against the foundation. Just use foam it is not really all that difficult to cut.
The best practice really is to use rigid foam against the foundation wall, then a framed (possibly insulated) wall with drywall and no vapour barrier.
Batt insulation in the framed wall is debatable. Green Building Advisor has articles that say it's not a good idea because it can absorb moisture, but others sources have no problems with it. If you do use it (I would if you are in a cold climate and don't have existing moisture problems in your basement), I personally prefer mineral wool over fiberglass.
Basement Insulation Diagram
Don't forget about the cavity above the wall in the joist spaces.
Trusted Sources (read them!)
Good Luck!
I don't disagree that foam is the best option, but the OP had specifically mentioned they planned on using fiberglass against a concrete wall. Given that, I don't see the downside of having something to reduce the risk of moisture in the insulation. – BMitch Feb 23 at 13:59
You are right, it will reduce the risk. But by how much is debatable. – decker Feb 23 at 20:35
Had they mentioned they had water issues, I would have suggested a 1" air gap and a perimeter drain. Without any issues, a bit of tyvek just seemed like a bit of insurance. – BMitch Feb 23 at 23:25
The main concern with vapor barriers and fiberglass insulation is preventing condensation and trapped moisture in the insulation that could result in mold and mildew. The vapor barrier on the conditioned (heated) side of the wall is there to prevent warm moist air from passing into the insulation and condensing on the cooler side. If you install a vapor barrier on both sides, moisture can become trapped inside the insulation and result in mold/mildew.
Tar paper is water proof and could easily act like a second vapor barrier. When used on a roof, there are typically soffit and ridge vents to keep the underside of the roof dry, rather than trapping moisture in the attic. However, on your basement wall, there doesn't appear to be anything that would allow trapped moisture to escape.
Tyvek and other house wraps are different in that they block liquid water, but not water vapor in the air, from passing through. This allows the walls to breath and prevents trapped moisture.
Therefore, in your situation, a house wrap product is probably best to prevent damage from any moisture in the walls from getting absorbed by the insulation and wood framing. Where the framing meets the floor, I'd be tempted to use either a vapor barrier, a foam weather stripping (it comes in a roll and is the width of the framing), and/or pressure treated lumber with nails designed for pressure treated framing.
We bought the tyvek - after looking at tarpaper and tyvek and the size of the rolls we decided it was an easier install as there would be less seams and tyvek seemed so much stronger that I thought there would be less chance of tearing when installing. Thanks – JanCamp Feb 23 at 13:16
The vapor has to go the other way, too. No plastic, no oil based paint or primer on the wall surface. – HerrBag Mar 23 at 14:51
