Tell me more ×
Over the past few months I've slowly been converting my garage into a DIY/project/man zone by adding lighting, work benches, storage and tools.
Next I'd like to mount a piece of transparent plastic to the wall to use as a 'whiteboard'
I know that I'd like to use a plastic, rather than glass, so that it wont easily shatter and will have more give to it.
Other than that I'd like a material that I can draw on and wipe clean, won't flex too much when I write on it and be as cheap as possible (whilst being up to the task)
Suggestions?
Is there a reason it has to be transparent? – Doresoom Oct 31 '10 at 1:56
I'd like to see my garage wall through it. So really just my personal asthestics – Peter Bridger Nov 1 '10 at 8:19
1 Answer
up vote 4 down vote accepted
Markee Dry-Erase Paint is clear, so it won't even look like you've got a dry erase surface at all. You may want to put up an outline though, since I could see running off the edge of the painted surface being a problem. It's also a bit pricey, at $59/quart or $127/gal. (I haven't used this product myself, so no guarantees on how well it works.)
Another option is Opti-White dry erase film, also in clear. It's $26/ft for a 5' wide sheet. (So a 3'x5' sheet will run you $78 - it would be cheaper to go with the paint-on option, unless you don't want to deal with the mess.)
If you want to go the 'board' route instead of a wall covering, you could try Lexan. It's fairly lightweight and you should be able to get it at most home improvement stores. Lowes has it for about $70 for a 3'x4' sheet.
With Dry-Erase paint you need to have a very smooth surface or it will not work very well (or you need to apply a lot of coats to form the smooth surface). Notice the Markee Dry-Erase paint mentions to apply 8-10 coats (this is so any bumps are smoothed out)... your garage wall might need more. – Jeff Widmer Nov 2 '10 at 10:49
Thanks for your input, I've decided to go the Lexan route. I've ordered a 900mm x 600mm x 4mm off eBay for £30. Fingers crossed it works out – Peter Bridger Nov 22 '10 at 18:38
@Peter: I'm sure the other SE users would love to see the finished product. Post pics if you get the chance! – Doresoom Nov 22 '10 at 19:51
