Tell me more ×
I recently bought an under-the-sink drinking water filter, a model from GE, and I got stuck trying to hook it up to the cold water line.
The package came with a simple plastic tee that had a 1/2 inch MIP, a 1/2 inch FIP, and a 1/4 inch connection for the tubing that goes to the filter. My trouble is that I don't have any 1/2 inch connections after the shut-off valve -- the connections there are 3/8 inch compression connections (I'm slowly learning the difference between the various fitting types).
I've been trying to find fittings that would let me adapt the plastic fitting that came with the filter for my situation, something like the following:
shut-off -> 3/8 fem comp x 1/2 mip -> plastic tee -> 1/2 tip x 3/8 male comp -> water line to existing fixture
But I can't seem to find anything like a 3/8" female compression to 1/2" MIP adapter. It also seems like having more joints in a plumbing system might cause problems, so using the fewest fittings possible sounds like a good idea.
Is there a better way to do this? Some way of avoiding the included plastic tee?
So, to restate my problem, how can I accomplish the following:
shut-off, 3/8" m comp -> 3/8" f comp x 3/8" m comp -> 3/8" f comp fixture line
                                  v
                         1/4" quick connect tube
FYI: MIP = Male Iron Pipe, FIP = Female Iron Pipe – Tester101 Feb 11 at 20:41
1 Answer
up vote 2 down vote accepted
You're going to need to get a 3/8" x 3/8" x 1/4" brass tee, like this one from Home Depot.
Then you'll simply screw the tee onto the male end of the shutoff valve (where the cold water supply line should currently be attached). Attach the supply line (that you removed from the shutoff valve) to the male end of the tee. Finish the installation by attaching the tubing to the 1/4" outlet using a compression fitting (Which should be included with either the filter or the tee).
The link, picture, and description are all very helpful! My local Home Depot and OSH didn't have anything like that in stock (and I certainly looked...). – Casey Marshall Feb 11 at 21:24
